Legal Bill
Hello everyone. I hope all are well.
The oil pressure gauge my '65 Healey 3000 MKIII vibrates, flickers or shakes. I'm trying to attach a video so you can see what I mean, but it doesn't work, so here is a description. The gauge still goes to 0 when the engine is off. The needle still swings to the 65-70 psi range when it starts, but the needle flutters between 50 and 80 psi. When hot at idle, the needle flutters between 10 and 35 psi. The needle is still in the same range as it was before this problem started, but it flutters almost all the time. Not always, but almost always. If you want the vid, send me your email and I'll send it to you.
I tried "bleeding" it. I never needed to do that before with a Smiths gauge, but I gave it a try. No change.
The engine has less than 1,000 miles on it. It was rebuilt about 15 years ago and I don't use it much. The car lives in a climate-controlled garage.
Any ideas what is wrong here? I do not have another oil pressure gauge that I am confident works.
