Oil pressure fluctuation
prb51
I've noted that after fully warm (20+ miles) when registering say 50 lbs. of oil pressure at 2400 rpm that slowing down a bit, lowering rpm will actually raise oil pressure 5 lbs or so.
What causes this?
Be sure you're not low on oil. Your pump could be starving.
prb: I guess my original reply was lost when the posts were restored.
I have found that fluctuations are caused by two things:
1. low oil volume - check your dip stick
2. air in oil gage feed line caused by a leak
I would check the oil pressure with a known good gage and then if the reading does not vary, your problem is the original gage/line.
Its not the oil level as thats topped up.
It only happens when hot and cruising at speed.
I've ordered a proper oil pressure test gauge and will check that out when it arrives....hadn't thought about the air in the gauge line. I suspect the gauge but we'll see.
