W
Wings
oil pan bolt questions
Rebuilt my bj8 engine 500 or so miles ago (broke another crank, thats 2 now) I just changed the oil for the second time it was a bit wetter underneath than i expected, looks like the front timing cover again, gonna tighten the bolts as best i can to see if that helps
on the timing cover it was just the bottom 3 bolts that took a tighten
BUT.....ALL (24) of the (DW aluminum) oil pan bolts took a tighten about 1/2 to 3/4 turn each I did these when we assembled so i am aware of the pressure applied. these oil pan bolts are modern grade 8, 24 count thread(i think, fine thread anyway) 550 miles and working themselves out ????
thoughts here,, guys
hot oil shrinking the cork?
go back to originals incase bottom of block is wintworth?
thread lock?
do what i do to valve cover? apply sealent on both sides (of oil pan)
thoughts
thread lock?
thoughts
