I had a hesitation problem on my 78 Spitfire. I checked the dashpot and it was empty. I added oil when I first installed the newly acquired used carb but it had leaked out. I added more (up to about 1/4" from the top of the shaft with the plunger installed) and on the first drive oil was all over the top of the carb, as if it leaked out the top of the dashpot. Is this normal? If so, why did I lose all of the oil?
Thanks!
Thanks!
