bighealeysource
Well, finally discovered the source of my minor oil leaks
on my rebuilt BN6 engine - the side covers on the right side of engine. I replaced the cork gasket for the valve cover
with one the new silicone type and that works great - highly
recommend. Then determined that I was getting oil leaking
from the side covers. So, replaced the old cork gaskets
installed when engine rebuilt about 3 years ago with new ones.
Also used red permatex gasket silicone and applied to both
sides of the gasket hoping to get a better seal. Was that
wrong to do as should I only have applied it to the block
side ? But was putting onto metal -side cover and block-
when did both sides -thought that would be better. Now
it appears it is seeping through the bolt holding the side
covers to the block. One bolt in the center of the cover
with a brass washer only. Thinking about using the high temp
red permatex on that bolt hole - y'all think that would work ?
Wouldn't think tightening up those leaking areas would hurt
anything but know a lot out there have far more wisdom then me! I lose enough oil that it drips down onto the frame rails
and marks its territory after every tip out.
Thanks,
Mike
Thanks,
Mike
Hi Guest!
