vette
Hello, everyone. It's been a while since I reported about the sever oil leak I've been trying to resolve on my BJ7. I've had it out 3 times this month so I,m pretty sure of my findings now. After changing all the gaskets on the side covers and the valve cover and cleaning down the complete engine I thought I had stopped the leak. Things were dry on the first two outings. Then yesterday, I notice oil again on the right side just along the top of the side covers. Earlier this was very prevelant and it appeared to come from the very front center of the valve cover then flow down the front of the head to the water pump area at that point the fan and wind was forcing it to flow along the seam of the head gasket. Well the oil has shown up again along the seam of the head gasket, but the valve cover gasket and frontal area of the head is dry as well as the side cover gaskets. It looks like the leak is truely the head gasket. I was going to retorque the head bolts when I changed the valve cover gasket and also adjusted the valves but it looked like it is necessary to remove the rocker arm shaft to get to some of the head bolts, so i didn't do it. I'm not sure that it would have improved the situation anyway. So it looks like I'm into a new head gasket job next. But, boy she sure still runs fine.
Dave, /ubbthreads/images/graemlins/frown.gif
