I have traced a significant oil leak where the steering pinion shaft enters the steering rack on my '73 B. I see in the parts catalogs that there is a "pinion oil seal" mentioned. Is this probably the source of my problem? Also, does the fix require the removal of the whole steering rack to get at the thing or could I be lucky enough to avoid this?
Thanks.
Thanks.
