RJS
Hi
I have small leaks from two areas. What's you opinion?
1. After engine shut down I get a small oil leak from the oil seal on the timing chain cover. I can see it dripping (1 drip every 15-20 seconds) from the crank for a few minutes. It seems to have started after I tightened the timing chain cover bolts when I had the cooling fan off. Is it possible by tightening those bolts I messed up the oil seal? Any chance I can "realign" the cover and get the oil seal to seal again? Or, am I looking at a removal and replacement of the oil seal?
2. I have an OD transmission. A while back I changed the tranny fluid to Redline MT-90. Tranny shifts great but, it seems to have developed small seeping leaks around the seals - trust me it is very small. Perhaps 1-3 drops if left in the garage for a montht. a) does this sound reasonable that switching to MT-90 synthetic would cause this? and b) would changing back to a conventional oil stop the leaks? Or, are the seals now compromised?
Thanks
Bob
Thanks
Bob
