jlaird
BUILDING A HIGH-PRESSURE OIL GUN FROM A
LEVER ACTION GREASE GUN
By Kevin Pinkerton
https://www.metalwebnews.com/howto/oilgun/gunconvert.html
Most metal working machines require oil to be forced through channels for oiling the ways and other parts of the machine. On many of the older-model machines these channels will be fitted with standard grease fittings, but you should not use grease on them. A special type of oilier must be used, one that can generate higher pressures than a standard pump-type oilier. It must also be equipped to pump oil through a grease fitting. I was able to build a high-pressure oilier by modifying a lever action grease gun with only a minimal effort and additional parts. The total cost was about $10. The oil gun works very well and does not leak.
First you will need to buy a good, low-priced lever action grease gun that used 14 ounce cartridges. I bought a PLEWS model 30-445 at an automotive discount supply store for under $10. The oil gun does not need the optional air bleed screw in the head assembly (something that usually costs extra). Look inside the tube before you buy the grease gun and check out the plunger. The oil gun described here requires a good large rubber plunger to help seal the hole the plunger rod goes through in the end of the gun (See Figure 1). I would also recommend a grease gun that comes with a rubber washer where the body tube screws into the head assembly.
Next, unscrew the end cap from the end of the tube body. Use a hack saw and cut the plunger rod in half to remove it from the grease gun. The rubber disk should slide easily off the rod.
The next step is to attach the rubber disk to this end cap with a bolt, lock washer, washer and nut to seal the hole in the end cap. This may take a little ingenuity on your part, depending on the shape and make-up of the rubber disk in your grease gun. The grease gun I bought had a large metal washer on one side of the rubber disk and some sort of metal cone on the other side of the disk. I removed the metal cone and left the metal washer. If your grease gun does not have a large metal washer, you will need to furnish one. You are going to put a bolt through the rubber disk from the metal washer side and then slip the bolt through the hole in the end cap so that the bolt sticks through where the plunger used to. Use the largest bolt that will fit through both the rubber disk and the end cap hole. Slip a washer, lock washer and nut on the end of the bolt, but do not tighten it down snug yet (See Figure 2). Next, put plumber's tape around the threads on the tube body and screw the end cap back on, getting as tight as you can with your hands. You should not need to use a pipe wrench. Once the end cap is back on the tube, tighten the nut down so that the rubber disk is compressed up inside the end cap. The compressed rubber disk should seal around the bolt and the hole in the end cap. It will also help to seal the seam between the tube body and the end cap. Do not over tighten the nut or you will destroy the rubber disk. Remember, the oil will not be under any pressure inside the tube (the piston in the head assembly generates the pressure needed to force out the oil).
To finish up the conversion, remove the delivery tube and nozzle from the end of the head assembly portion of the grease gun. Then wrap plumber's tape around all the threads and re-assemble the delivery tube and nozzle. I replaced the metal delivery tube with a flexible tube on my oil gun. Now you are ready to fill and use.
Hold the tube body capped-end down and fill the tube with the appropriate oil. Screw the piston head assembly back. You will need to hold the oil gun so that the oil flows downward toward the piston assembly located in the head when you use it. I recommend storing the oil gun with the nozzle end up.
The design for this high-pressure oil gun is based on several good ideas that were offered in the rec.crafts.metalworking news group. Thanks for everyone's input.
Kevin Pinkerton
https://www.mgaguru.com/mgtech/tools/oil_gun.htm
Check google for "pom pom grease gun" seem cheep enough but all the ones I could find are in england and Australia.
By Kevin Pinkerton
Kevin Pinkerton
