The only tip I would give you on this, is sneak up on your tapping with the NPT 1/4 tap, you want the plug flush, not sticking out, or countersunk in. tap alittle bit and check, then a lttle more, to get it exactly where you want it. Oh and get steel plugs and avoid the brass one, they tend to strip out the allen head when you want to remove them in the future.
