TR2/3/3A Oil Filter/Regulator Head
CJD
I've moved on to the oil filter head. I cannot find a supplier for the rubber seal that goes under the pressure regulator, and the lead washer that goes under the pressure adjustment locking nut. Has anyone found a supplier for these seals?
TRF seems to have the seal listed. Ordinary solid solder should do for the lead washer, but I would probably use a copper washer instead.
That's what I love about you Randall...I sat there for hours thinking there must be an easy solution to the lead washer. You've got it right off!
Thanks!
