OIL FILLER CAP
Healeybird
My oil filler cap is leaking bad. Anybody know if there is a replacement seal or will I need to by a new cap? Moss just showed the cap with cable and I would like to avoid having to paint a new one.
Hi HB, you might want to check the rocker shaft it may be worn and spurting oil. You can also take the cap to A good hardware store and see if you can not match the rubber up with one of the gaskets in the plumbing department.--Fwiw--Keoke
