sparkydave
Since it was almost time for an oil change anyway, I put Castrol 10W-30 in instead of the 20W-50 I've usually been using. Partly because the thing is nearly impossible to turn over over winter, but I've never liked that it takes a second or two for the oil pressure to register. Already I noticed a few differences, like the valves are quieter, the oil pressure comes up much faster, and the strange squeal I've always heard for a few seconds after starting it cold seems to be gone. The latter I've figured was the release bearing, so it could be completely unrelated. Anyway, the oil pressure is still around 60 PSI at speed and about 25 when idling.
In other news, if anybody needs to replace the oil pan, and you repaint the replacement, make sure the drain plug can be removed easily or put some oil on the threads before you bolt it on. Let's just say this was the first oil change since that event, and thank goodness for Vice Grips /ubbthreads/images/graemlins/jester.gif.
