beez
I'm in the process of installing an oil cooler on my car. I have the spin on adapter installed, the cooler mounted the the tubing run to the thermostat. Apparently the thermostat must have the oil flow a certain way through the contraption in order to work properly. Does anyone know which port on the spin-on adapter has the oil flowing from the engine? I have it plugged into the top port if the filter is facing down.
Thanks!
Thanks!
