jaybird
Oil Changing Instructions
Women:
1. Pull up to Jiffy Lube when the mileage reaches 3000 since the last oil change.
2. Drink a cup of coffee.
3. 15 minutes later, write a check for $40 and leave with a properly maintained vehicle.
Men:
1. Go to O'Reilly auto parts. Write a $50 check for oil, filter, oil lift (aka kitty litter), hand cleaner and scented tree.
2. Dump old oil from last oil change in back yard.
3. Open a beer and drink it. Jack car up. Look for jack stands.
4. Find jack stands under kid's pedal car.
5. In frustration, open another beer and drink it.
6. Place drain pan under engine.
7. Look for 9/16 box end wrench. Give up and use crescent wrench.
8. Round off drain plug hex with crescent wrench.
9. Unscrew drain plug with vise grips.
10. Drop drain plug in pan, splashing hot oil on you.
11. Clean up using hand cleaner. Have another beer while oil is draining.
12. Look for oil filter wrench.
13. Give up. Poke oil filter with phillips screwdriver and twist it off.
14. Drop oil filter in full oil pan. Clean up a big splash.
15. Beer. Buddy shows up. Finish case with him.
16. Next day, drag pan full of old oil out from underneath car.
17. Throw oil lift (aka kitty litter) on oil spilled during step 16.
18. Beer. No, drank it all yesterday.
19. Walk to 7-11, Buy beer.
20. Apply thin coat of clean oil to filter gasket. Install oil filter.
21. Remove oil filler cap. Drop it down there somewhere.
22. Dump quart of fresh oil into engine. Remember drain plug (step 10).
23. Feel around in full drain pan to find drain plug.
24. Clean dirty black oil from hands (step 23).
25. Install drain plug. Stay out of fresh oil on the floor.
26. Slip with crescent wrench and bang knuckles on frame.
27. Bang head on same frame in reaction. Begin cussing fit. Throw wrench.
28. Hit Miss December 2002 with wrench. Cuss additional 10 minutes.
29. Clean up. Apply Band-Aid to knuckle.
30. Beer. Dump in remaining 4 quarts of oil.
31. Look for lost filler cap (step 21). Give up. Stuff old rag in hole.
32. Lower car from jack stands. Accidentally crush one jack stand.
33. Move car back. Throw oil lift (aka kitty litter) to spill (step 22).
34. Drive car to O'Reilly's. Buy new filler cap and one quart of oil.
35. Open hood in front of O'Reilly's. Remove rag (step 31).
36. Pour in oil. Install new filler cap. Check oil level on dipstick.
37. Go back in O'Reilly's. Buy another quart of oil and a filter wrench.
38. Crawl under car. Tighten oil filter. Burn arm on hot exhaust pipe.
39. Remove new oil filler cap and dump in another quart of oil.
40. Ignore the oil trail made going to O'Reilly's while driving back home.
41. Stop in front of the 7-11 when the old oil filler cap goes bouncing down the pavement. Stock up on beer while there since it's almost time for a spark plug change.
Women:
Men:
