George Zeck
Hi All -
My front end is way off. In process of double checking allignment, refilling dampeners, replacing front bearings. Symptom: Worn VERY unevenly after ~ 3k miles. Front tires are shot.
Problems identified (so far): Loose mounting on one dampener, worn bearings (both)to be replaced and unknown accuracy of allignement.
The thought came to mind when I replaced the bushings last year that I might have installed them wrongly. Bushings are offset and IF I inadvertly placed them in backwards - the camber (OK, some type of adjustment) would be off significantly causing the tire to ride unevenly on the road.
Am I "overthinking" this problem ? This "offset" really has thrown me for a loop. Anyone familar with this issue ??
Tx-
George
/ubbthreads/images/graemlins/hammer.gif
Tx-
George
