I am officially at an almost complete loss on what is happening with my TR3A. Was running great before I put a ecored radiator in it. Now I cannot get it to quit backfiring under any but the lightest load/acceleration. New thermostat, new temp gauge, it barely registers over 155 degrees as compared to 180-185 before. Here are the things I have tried to absolutely no advantage or noticeable difference:
-Cleaned carbs up, changed Marvel Mystery Oil that has always worked fine in dampers for 20/50 motor oil. Adjusted
advance from about 3 degrees to probably 20 and many, many points in between. Replaced thermostat that tested fine. Watched carb piston/needles rise and fall smoothly and in unison to the best my eye can tell. Three, count 'em three, sets of spark plugs. All are looking black and sooty to the same degree but nothing worse than I have seen before. Slipped plug wire boots up to make sure that all wires were making good contact with plugs. Almost new rotor, cap and points...that had been working great before.
The only thing that is different that I am aware of is a newly recored radiator. Had a TR250 fan on there but went back to the original when I saw the temperature was so much lower. I am actually thinking of completely removing the fan to see if I can get the temperature up. I am going to check the points gap next but I am grasping at straws with that because they have not been in there very long at all. Also, if the timing was off wouldn't my changing it so drastically from 3 to 20+ degrees affect the backfiring? It is exactly the same at each end of that crazy spectrum and in between. It idles great at 800.
Here I stand. I cannot do otherwise.
/ubbthreads/images/graemlins/nopity.gif
