So I was checking the Tunebug's wiring tonight, and I'm having trouble getting the horn to work.
I've checked that I've got good wire runs to the horn itself (harness was new as of 4 years ago). Horn works if I run wires directly, or if I run a direct wire from the ring on the steering column to a known good ground.
The problem seems to be in the connection from the steering column itself to ground. In looking at the diagram and the mechanics of it all, it would seem that the horn works when the ring is grounded. The horn button would also seem to be grounding this through the steering wheel hub and on to the column.
If I run a continuity test from the center of the column to a ground, there is *no* connection. It is acting like it is not grounded.
What am I missing?
What am I missing?
