OD Wiring questions.
vping
I ran the wire to the harness for the OD but I still have Light Green wire with a White stripe (partially attached)and a green wire with a Yellow? stripe (for now attached to the Green with brown/Red stripe)to attach and am not sure where they go. The only wires I have to attach to are a Yellow with Orange Stripe and a heavier gage White with a black stripe (you can kinda see this off center to the right under the large blue taped harness)
Any clues?
PDWA?
Pressure differential warning actuator. The brass thingy on the drivers inner fender. Has a bunch of brake lines sticking out of it. And hopefully a nylon switch in the middle of it.
Those are all plugged in already.
Two wires plug into the PDWA. Two wires plug into the brake light switch. The other ends to these wires die in the harness somewhere.
Sounds as if you may be the victim of DPO "wiring improvements" Vince. Have you the AdvanceAuto diagram for the car?
I've the Bentley.
Here's another shot of what still needs to be hooked up & what can be tapped into.
There's a diagram for you in the right section:
https://www.advanceautowire.com/
You can have the proper one printed BIG at a Kinko's or other outputter.
The green/brown should be the tank sender, IIRC.
Yeah that is the one I printed and am using.
