I have an original Lacock manual, which I will examine tonight. I recall there was a specification regarding engagement time folowing energizing the operating solenoid. But, remember this can get complicated because there are many variables. Things that I would look at:
- voltage that is delivered at the solenoid
- free mechanical operation of the solenoid, is it free to move, clean, not gummed-up, etc.
- condition of hydraulic fluid (oil), the viscosity of which will change with temperature as previously stated.
- more advance test will require a high pressure hydraulic guage, 0 to 500psi, and do the test in the shopmanual. You may have a marginal pump.
Also, I would monitor this for a while and try to correlate with some of these variables and note if the condition is stable of is getting worse.
BUT, dont worry, these units are robust and serviceable and all major components are available.
Cheers,
Frank
