Guys, I need some advice for the OD on my car. Since I bought the car, the OD has never worked. I recent took the trans tunnel off to investigate this and found 2 issues. 1) My OD no longer has the rubber bump stop under the solenoid plunger. Neither Moss or VB carries them. Can anyone advise where to get one, or how thick it is so I can make one? 2) When the car is parked and the engine off, I put the shifter into 4th gear and flick the toggle switch on and the solenoid seems to engage the OD properly....however when driving in 4th gear, when I flick the OD switch on, the OD will not engage. But if I manually push the valve setting lever down, the OD engages and operates perfectly. Has anyone had a similar issue. Any help would be greatly appreciated. Thank you. Bill.
