Lukens
Hopefully someone can explain this issue. I've got the clearance between my slave cylinder piston and push rod properly set. I'd like to think there is no air in my system (I've bled it repeatedly). I can depress the clutch and it will hold (no leakage in piston seals). The clutch engages and disengages properly. But... occasionally, maybe once in a hundred shifts, I can feel excessive pedal travel before the clutch disengages. I pump it a couple of times and all's well.
What's going on?
As always, TIA
Russ
What's going on?
As always, TIA
Russ
