Morris
I have hooked up a Wideband 02 sensor to my '79 Midget, and I believe the blow by in my engine is corrupting my signal. With the crankcase vent tube plugged into the carb, the car reads a little richer than without. This seems to be regardless of whether or not the tube to the charcoal canister is plugged in.
Is there a way to vent the crank case without plugging into the carb? If I just pull the tube and allow it to vent to air, oil blows out the dip stick when the engine is under load.
morris
morris
