Bret
In relation to my Speedo question in another thread.
I'm getting ready to install my O/D transmission but I have a few questions about how the overdrive solenoid is engages with the shifter switch.
I’ve got the shifter knob with the switch ready to go but looking at the Moss & VB catalog and perhaps I missed it but I couldn’t find the any reference of the O/D vs. the none O/D transmission wiring harness that I need.
Anybody is this something I can mock up on my own or do I need to have the wiring harness. I assume I can just pick up the 12v to actuate the O/D solenoid using the “fourth gear” wire that connects to the 4th gear vacuum advance solenoid. So I’m guessing that if the None O/D & O/D main wiring harness are identical – there should be a connector under the trans tunnel that I can connect to.
Any thoughts?
Any thoughts?
