I had a 1/2 inch diameter stud (BSW one end, BSF the other) on which the BSF nut had been screwed down to the end of the thread, so when I tried to remove it, the stud came out of the aluminium clutch housing. I could not grip the stud tightly enough to persuade the nut to undo, liquid wrench made no difference, and I didn't have two BSW nuts to form a lock-nut. (I have no replacement stud, so I didn't want to damage the threads).
As the suggestion of a friend, I took a disposable nut (actually 1/2 inch UNC), sawed it in half across the diameter between two points so I had two U-shaped pieces with flats, and used those as jaw adapters in my vice to grip the unthreaded part of the stud. It was so simple and worked so well that I wanted to pass on the tip.
Ken G, 1925 Rover 16/50 (San Francisco)
