RobSelina
Just took the spitfidget out for a spin after my last round of mods/repairs and I don't think I could have been grinning any wider /ubbthreads/images/graemlins/grin.gif
Here's what I got done:
- replaced rear wheel bearings/seals
- replaced rear drums and shoes
- rebuilt driverside rear wheel drum (pass was a-ok)
- replaced a-arm bushings with poly
- replaced trunion bushings with nylatron offset bushings from winners circle.
- brembo rotors & hawk hp+ pads up front
- fixed leaking fitting on driver side caliper
- cleaned up caliper pistons but did not rebuild (not necessary)
- replaced brake MC cover (thought it needed rebuilding but it was just the leaking cover gasket)
- valvoline synthetic dot 3/4 brake fluid
- rotated tires
- built new spherical rod-end swaybar end links
- upgraded/finalized my front and rear tube shock conversions - replaced all the hardware with grade 8 and added aluminum spacers in place of washers I had put there 'temporarily'.
- 13" RPW wheel and removable hub.
The car's handling and braking are MUCH improved. As some of you may recall, I recently did some maintenance to the engine and upgraded the intake and exhaust system which suddenly made some braking problems much more apparent now that I had a little more 'get up and go'.
Some thoughts:
1 - poly bushings do not ride hard at all, but the responsiveness from the wheel is much improved.
2 - the offset trunion bushes are GREAT. Really helps cornering. I would run these on any spridget with radial tires. 1.5-degrees negative camber is not that much.
3 - spridget brakes don't have to be soft! I can't believe how much different my brake pedal feels. You'd think I had just installed a brake booster, they work so much better! For those wondering I have a stock system in good shape with three improvements: stainless braided lines, hawk hp+ pads and brembo rotors.
4 - Nial had reported that the Hawk pads fit loosly in his calipers and one rotated. Mine seem to fit just fine. One problem though was that the first set Moss sent me had a defective pad that had been milled at an angle on the abrasive side. It was off by around 3/16". The second set they sent me were all fine. I want to wait and see how they perform long term, but my initial observations are positive.
Anyway, this was just a quick run to bed the new pads, but I can't wait to take her out for a real drive tomorrow! /ubbthreads/images/graemlins/cheers.gif
I just wish it would stop raining! I reinstalled my soft top today so I'd be able to drive it, but I much prefer to leave it off the vehicle....
- rotated tires
Some thoughts:
