In a classic case of DIY gone seemingly wrong, after I've fiddled with various tune-up items (new plug wires, new coil, gapped points, adjusted valves, carb) the tunebug seems to be running hot. The carbs are probably off--I was warming up the car to re-adjust them when I noticed the little guy was running at 190. It is usually at a pretty steady 180 around here.
Could I have tweaked something in the tune-up process that might cause this. Another possible consideration is that the coolant is probably out of mixture, with more water than normal. Also, I'm at 5550' elevation.
I'm trying to get the Tunebug ready for the show on Saturday, so any help is appreciated. I think I have all the bits in place, just need to get them all adjusted so he will run as well as possible.
