2wrench
Please review following possible parts list for
early '74 TR6 rebuild. I seek advice on possible
upgrade(s) that should be considered. I'm looking to
have a strong running street machine.
Also want to listen to voices of experience re rebuild.
I might wimp out and go directly to machine shop with
everything saying just do it. Please tell me what I
might be missing to consider in updating the materials
list. Looking first at worst case scenario to get an idea
of costs. Things will change once she is apart, I'm sure.
Cylander Head
Exhaust Valves
Intake Valves
Valve Spring Set
Valve Spring Guides
Valve Seats
Rod Bearings
Main Bearings
Connection Rod Bushings
Core Plug Set (Soft plugs)
Cam Shaft
Upper and lower gasket sets
Oil Pump
Front Oil Seal
Thrust Washers
Timing Chain Gears
Rear Oil Seal
Piston & Ring Set
Lifters
Timing Chain
Timing Chain Tensioner
Thanks,
Cylander Head
Exhaust Valves
Intake Valves
Valve Spring Set
Valve Spring Guides
Valve Seats
Rod Bearings
Main Bearings
Cam Shaft
Oil Pump
Front Oil Seal
Thrust Washers
Timing Chain Gears
Rear Oil Seal
Piston & Ring Set
Lifters
Timing Chain
Thanks,
