Hello
My BT7 has a mysterious oil leak which I'm hoping someone can help me with. During a recent 200 mile trip across Texas the oil level was reduced from almost max to below min on the dipstick. The oil is not coming out from the exhaust but is exiting the engine somewhere else with a lot of it ending up on the inside of the hood and in the channels around the engine bay and a lot more of it is finding its way onto the outside of the exhaust and under the car.
The oil that ends up on the exhaust is being burnt off giving me a nice big cloud of smoke to follow me around. This smoke is intermittent and I was unable to correlate it with anything I was doing except to say that it generally does not happen below 60 mph. Other things: oil pressure is good - just over 40 psi at 3000 rpm warm and the car is fitted with a vent can (by previous owner) so a line goes from the rocker cover to the vent can and then from the vent can to both the air intake and the block.
I am currently suspecting this oil is leaking out from the tappet covers only because there is some oil on the block around these and I cannot see anywhere else on the engine with any telltale signs that it is the culprit. Before I start to dismantle my engine, does anyone have any ideas what could be the cause of my oil leak or has anyone experienced it before? Thanks for you help.
Regards
Myles
Regards
Myles
Hi Guest!
