rjc157
Recently had my tach rebuilt by nisonger to have it accept a petronix unit it eliminates the loop ,my car was converted to negative ground yrs ago and not sure what the mechanic did ,I connected the wire from the tach to the neg side of the coil and connected the petonix as told to do red to + and black o - nothing ,looking at the switch here is no lead coming from the the # 2 post should I run a wire from it to the + side of the coil .Now does the black and white wire from the cut off switch go to the neg side or pos side thiif for a bj8,fuel pump works as well as the ignition light switch
Hi Guest!
