TulsaFred
A couple weeks ago I ripped out my old wiring harness in the bugeye.
In order to run the car I ran a jumper with aligator clips for the fuse block to the coil (the terminal opposite the one that runs to the distributor).
I pull the starter solenoid under the bonnet and it cranks and starts no problem.
Until today.
Went to start and nothing.
I pulled the number one plug and layed the electrode against the block and I don't see any spark jumping the gap.
I did leave the jumper in place, accidentally, this time, so the coil has been seeing a constant 12 v.
I checked using a test light and I am getting current to the coil terminal using the jumper, but it seems like no spark coming out.
Any ideas on the problem?
Until today.
