The other day my BJ8 failed to start when I tried to go home after work. It wouldn't turn over at all. We did some trouble shooting and determined that the starter motor didn't appear to be working. We removed it, cleaned the brushes and commutator and then bench tested it. It worked! We put it back in and it spins like a champ.
Unfortunately the car is not starting. I checked the plug wires near the block and I don't appear to be getting any spark. In addition, the coil is getting hot a blazes (not sure if that is normal or not). Does anyone have any troubleshooting suggestions or ideas about what might be wrong?
I read in the workshop manual that I can rotate the distributor until the points are open and then check the voltage on the starter, but the distributor is a black box to me and I'm not sure how to tell if the points are open. Any suggestions at all would be appreciated.
Thanks,
Drew
Thanks,
Drew
Hi Guest!
