no spark
jjh
Member
Long story... But my 75 B was allowed to run out of fuel. Now it will not start.cranks fine but no spark. I can hear the fuel pump and I've treid starter fluid in the carb no good. I've changed the points,condenser and rotor and replaced dizzy cap which I discovered had a hole under one of the hold down clips. Still won't start. The weather is finally getting nice. Help!
have power going to the coil?
Got the points gapped correctly and she fired right up. thanks all , with a little luck, I may be able to go to Britfest tomorrow.
