no spark to plugs!!!
Up and running
Well, thanks to you all I've got it running, thank you! I changed the condenser and the points, replaced dist. cap/wires, new spark plugs, removed and flushed gas tank/lines. Probably only needed to replace points/condenser but I figured I was there so I replaced all of it. My next venture is the braking system - does anyone have any suggestions for a complete brake job - the right rear tire was froze upon purchase, rear pads are ruined, front calipers look okay - should I just replace everything? Thanks again for all your help
