Musicman
Hello to all in Triumph land. Just wanted to chime in and let you guys know what I've been doing the the 6. When I got the car a couple of years ago I did some major work - entire front suspension redone, new stock muffler, tailshaft seal, pinion seal, and new sub axles with seals. I also replaced all little rubber parts like the hood stoppers, the little grommet that's on the overflow bottle, etc.
Just recently I had the timing chain cover gasket and front crank seal replaced, new oil pan gasket, rear main seal, the seal at the front of the tranny, new master cylinder, and all the little seals and o-rings up in the shift rod area above the tranny.
I think that's everything. It's still early in the morning so I may have forgotten something but that's pretty much it.
The car doesn't leak or drip anything anymore! Can I still call it a Triumph?
Dave
Dave
Hi Guest!
