Have a big problem that requires your input, please.
Did all of the necessary things to start the BJ7 after a complete mechanical rebuild. Filled the oil filter, used a pressureized pre lube kit (oil from the kit was being ejected from the rocker shaft, so assume that the oil galleys are clear, block was hot vated during rebuild,) Removed plugs and rotated the engine for approx a minute, oil pressure did not build. Started engine momentarilly (15-20 seconds), sill no pressure. Removed oil pressure union from block and rotated engine, no oil appeared. Dropped pan and removed oil pump, the original one. Put pump in a pan of oil and spun with a drill. Pump appears to pump oil. Check clearance between pump gears and pump case. Specs indicte one thousands tollerance. My readings approx 4-5 thousands. Would this amount of wear cause the pump to be unable to pump oil throughout the engine? What are some other areas that I should address? I am really stumped. Can anyone tell me the path oil takes when it is injected into the oil pressure gauge union. How can I ascertain that the oil passages are clear?
Need your expert suggestions. Was sooooo disappointed that the oil pressure did not register after waiting so long to finally start the engine.
Cheers,
Ray
Cheers,
Ray
