T
Tinster
Whew!! Crypt Car was almost a goner.
Jeff Paltech was dead on correct with his diagnostic
advice about why the Crypt Car refused to start with
Jeff's fantastic carbs and Dan Masters great new wire
harness.
Jeff suggested I had an air leakage problem and that
I might not have tightened down the new manifold clamps
and carb nuts.
So I got up at 4:30 AM this morning so Wendy would "catch"
me working on the Crypt Car. Sure enought I had completely missed tightening one of the lower, hidden manifold clamps. Bill knows excatly which one I missed, don't ya??
A few of the others were not as tight as they could have
been. I am afraid of breaking off studs, considering how
difficult it is to obtain replacements here on the island.
I kinda lost track of time and so there I am sitting in the
car, choke pulled out full and locked. A spritz of gasoline
in each carb and ready to turn the ignition key.
BLARGH!! Out walks Wendy- way early of her normal 8:00 AM
rise. I get "the look" and have no choice but to turn the
ignition key while she is glaring daggers at the Crypt Car.
After a few false starts I was able to get the car running.
One or two backfires, and the Crypt Car engine is spinning
under it's own combustion power. The car will not run at low
speed idle but I think that's just minor adjustments.
Oil pressure at a constant 75 psi at moderately fairly
high idle rpms. I think that might be a good
indication my engine may not need a total rebuild.
Dan and Mike Masters!! What do you think?? Jeff's carbs
with your wire harnness, Mike's help on the wire install.
The Crypt Car actually continued to run until I turned the
key off. First time in 8 months the car has actully run
under it's own combustion with pedal feeding gas.
I think I bought a few weeks before talk of the car
crusher becomes a daily routine.
Paul, Maybe that TR6/beach photo you want might not
be that far in the future.
Thanks all for your support and encouragement.
What a learning curve this has been for me!!
Dale
/ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif
harness.
and carb nuts.
Dale
Hi Guest!
