Newbie
69sprite
I have been watching this forum for a few months, before actually joining... I have seen a few of the people I have communicated on SpriteSpot with, so hi to you all..
I am trying to get my '69 MKIV Sprite back together and on the road again after having taken it down to refresh the engine and do a Rivergate conversion. It has taken quite a while since 'other' non-automotive tasks seem to get scheduled for me. I am down to the last few items (so I think). I just wanted to forewarn you all that I may start asking many questions as I get to the initial fire-up stage...
To help pay my way here... I thought I would leave you all with a little humor...so here goes...
We all know Murphy's Law.
In a recent inventory of Mr. Murphy's Work Shop, the following items were
identified:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings your
beer across the room, splattering it against that freshly-stained heirloom
piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and hard-earned
guitar calluses from fingers in about the time it takes you to say, "Yeou
sh$t...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters. The most often tool used by all women.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up
jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle.
It transforms human energy into a crooked, unpredictable motion, and the more
you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or ½ socket
you've been searching for the last 45 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you
have installed your new brake shoes, trapping the jack handle firmly under the
bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of
a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill
bit that snaps neatly off in bolt holes thereby ending any possible future
use.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably
has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop
light, it is a good source of vitamin D, "the sunshine vitamin," which is not
otherwise found under cars at night. Health benefits aside, its main purpose
is to consume 40-watt light bulbs at about the same rate that 105mm howitzer
shells might be used during, say, the first few hours of the Battle of the
Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
for opening old-style paper-and-tin oil cans and splashing oil on your shirt;
but can also be used, as the name implies, to strip out Phillips screw heads.
Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert
common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power
plant 200 miles away and transforms it into compressed air that travels by
hose to a pneumatic impact wrench that grips rusty bolts which were last over
tightened 30 years ago by someone at Ford, and instantly rounds off their
heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you
needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as
a kind of divining rod to locate the most expensive parts adjacent the object
we are trying to hit. Women primarily use it to make gaping holes in walls
when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents such
as seats, vinyl records, liquids in plastic bottles, collector magazines,
refund checks, and rubber or plastic parts. Especially useful for slicing work
clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while
yelling "DAMMIT" at the top of your lungs. It is also, most often, the next
tool that you will need.
Seeyaround...
Larry Swofford
Sounds about right!! Welcome to the forum!
man ... i haven't laughed like that in awhile! and you know why??? it's all true and happened to me ... especially the dammit tool! .... welcome and ask away!!! thanks for the laughs ... that's a keeper!
/bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Welcome
Oh, we gona have a party, cool.
Yeah, I think I've got one of each of those.
Bayless
