My best advice is to make sure you really need one. Very few harnesses really need to be replaced. I would replace one only if the insulation is burned, crumbling, or otherwise failing. The wire underneath is probably fine, as is the insulation under the wrap.
Most electrical problems are at connections. Replacing the harness will replace the connectors on the harness, but the tarnished or corroding mating connectors are still there, causing trouble. There are all kinds of automotive electrical connectors available. Replace those god-awful bullet connectors with something reliable, replace any bits of wire that are in bad shape, solder and use heat-shrink tubing for insulation. I think you will be way ahead of the game.
