I have now purchased two VB windscreens. The first caught a rock and cracked during my first 5 or 600 miles of driving, much to my disappointment.
The Good: They ship promptly and in a huge foam filled box, so the glass arrives intact and ready to install. It is much cheaper than the other Big Two.
The Bad: The fit is just OK. At each lower corner, the VB glass does not extend down into the windscreen frame, so there is a very small gap on each side.
This has been a challenging install both times. I don't know if that is because of the VB glass thickness, glazing strip thickness, or if it is because that is just how it is supposed to be. After properly soaping this up with dish soap, I used three clamps (pipe clamps used for compressing woodworking projects) to push the frame over the glazing strip and glass. I am sure the mechanical clamp install method is risky, as you could break the glass. But there is absolutely no way a few strong gentlemen could compress this without that clamping assistance. I used a small tube of Permatex black silicone to fill the gaps at the lower corners. As info, I believe the glazing strip that VB provides is the same as Moss and may have had a Moss part number on it, if my recollection is accurate.
I think it looks fine and the full glass swap out was less than $250. Hagerty would have paid for glass replacement for $500. I'll be tempted to let them pay the bill next time, as this is always a difficult install.
Pat
