Jim_Gruber
Bugsy got a new set of wheels today from the UK. I can't believe the condition of the box that they came in. Box we banded together with really crappy sealing tape and wrapped with some external cardboard. By the time it arrived the bottom box was totally toast. However everything looks great. I did find one tiny nick on one of the rims but I'm not going to argue about it. These look pretty darn nice, with full set of lugs and center caps. Now to find some silver AH Logos to go on the center Caps. Here is what arrived. And yes that is a rim sticking out of the top of the box. Wheels are by JBW(John Brown Wheels) and not I did not buy direct from these Factory in the UK but from a vendor called Waterford Classics. Wheels are 5 x 13 x 101.6mm. I think that is correct with 20 offset. At the Factory Website there were 5.5 and 6" sizes available.
I will need to grind the top of the Tie Rod End Stud as it hits and touch up the edge of the Tie Rod Nut with the grinder. Other than that all is good. They are pretty:fat:. Different from VTO's as they have a polished ring around the edge rather than a wide flat polished edge. Weight not too bad. I'm chuffed. Now to find some rubber to go with the wheels.
View attachment 47316View attachment 47317
