Rut
OK, I know I'm new here, but I went to the small, local parts store to get a few odds and ends and saw a 1 man brake bleeder kit. The thing is made by Lisle and it's very simple...3 adapters, 1 long tube, 1 short tube, and a container with a fluid tight cap. It was under $10 so I said what the heck and bought it. I used it to bleed the slave cylinder on the clutch and it was the easiest 1 man job I've ever done. Crack the bleed valve open, put the adapter on, push the clutch pedal repeatedly until you get clear fluid, close the bleed valve. I wish everything was this easy! The part number is 19200 if you want to look it up.
Rut
Rut
Hi Guest!
