dklawson
I moved my old compressor last week. Its Harbor Freight auto drain had plugged leaving a couple of cups of water inside. Along with the water were a LOT of decent size chunks of rust. As the tank is 40+ years old I decided it was time to retire it. New tanks cost about 1/2 to 2/3 the cost of a new compressor. New cast iron pump compressors with the CFM I want are north of $500 so I found and purchased a good used one locally.
The "new" compressor looks showroom new and clearly hasn't been used much. However, I heard water inside and decided to carry out maintenance before using it. I opened the drain **** and all it did was slowly drip. I dropped the tank pressure to about 10 PSI and slowly unscrewed the petcock. Even with the petcock removed all the tank did was drip. I grew impatient and probed the port with a bent coat hanger. Then all heck broke loose. I disloged whatever had plugged the port and about a quart of muddy water geysered out against the floor splattering me and most everything close in the garage. That will teach me to be impatient. I should have at least taken the thing out to the driveway. Now that I have cleaned the tank, the garage floor, and me up, it is time to move on to different plumbing and a better auto drain.
I want a better auto drain than the Harbor Freight one... one less likely to plug (which is what I found wrong with the HF one). The electric timer based ones don't make sense for a home shop (adjustable drain time 1-10 seconds every 1 to 45 minutes). They can also be expensive (Chinese from about $25 to name brand U.S. for upwards of $160).
Now that you know the background it's time to finally ask my question.
I am considering buying a programmable timer and solenoid valve to make my own more flexible auto drain. Before I start that project, do any of you use auto drains and if you do, are you pleased, how is yours adjusted, and how much did you pay for it?
