Nunyas
I got my 'B's shoes resouled today (a full set of shoes would include wheels in my book) with 185/65 14's. Smaller in diameter than the 185/70s that I got her with, but within a half inch in diameter of the tire sizes The MGB Experience and British Motoring says to be the original stock tire size (165HR14). So, the speedo shouldn't be too far off, drive testing seems to verify this, as going 10MPH over the posted limit still has me passing people left and right.
First thing I noticed after she was shod with new rubber was that she no longer wiggle wobbles... YAY! The next thing I noticed was I KNOW when I hit an imperfection in the road. Meaning, cracks, "patches", and road reflectors are positively felt. It's almost "jarring", but not to the point of "brain rattling". I think this is mostly because of the tire store inflating the tires to the "maximum recommended inflation pressure" of the tire. Over all the ride quality is still comfortable but well within the realm of being sports car 'stiff'. I think the harshness can be lowered if I play with the tire pressures and make them closer to MG specs. Obivously, I can't use the exact MG recommended tire pressures due to the different tire tech, but I'm sure lowering the front tires by evan 5psi will produce noticable results.
Next up was how easy the steering wheel turned. It felt like I had power steering compared to before. I had to make a conscious effert to not crank the sterring wheel like I had gotten use to. I can now navigate a parking lot with 1 hand. In the past I had to use both hands in crowded parking lots.
The anti-sway bar that I installed a couple of weeks ago made a significant improvement in normal day to day driving with the old tires. Body roll in turns was reduced so much that it feel like an entirely different car. With the rain we recieved early this week, I definitely found that the car now tends to under steer while making a U-Turn. The fun of discovering this was using the gas pedal to change under-steer into mild over-steer /ubbthreads/images/graemlins/tongue.gif
The new tires took the already improved steering response (thanks to the anti-sway bar) and made it even better. I can definitely feel a huge difference with the new tires. The old tires (185/70s) had a lot of side wall flexing. How much flexing was going on I did not know until I got the new tires. The old tires gave the 'B a boat-like feel in turns, albeit a john boat, but a boatish feel none the less. At first I thought this might just be how the suspension was, but now I know it was the tires. The side wall flex of the old tires may well have been what I've been feeling at the rear of my car when I thought the axle was sliding around. Actually, I'm pretty sure that's what it was.
I took a spirited drive through a near-by canyon/mountian pass road (La Tuna Canyon). The turns aren't very sharp there. They're mostly long sweeping turns, but the road isn't perfectly flat, and the humps and bumps made the old tires flex a lot while driving the road. The flexing of the tires on this road while in the turns was so unnerving that I never went over 50MPH on it. With the new tires, I took it at 60 both down hill and up hill. Never once did I feel the sensation of the car wagging in the turns to be caught at the last second by the grip of the tires. A turn of the wheel instantly told me that the car is going to do exactly what I tell it and when I tell it.
To top it all off, the car is the flatest I've ever seen it in ANY turn now. There's some minor body roll still, but compared to what it use to be the current roll might as well not even exist.
The over all handling is almost exactly what I envision when I hear you folks talk about the 'B's great handling characteristics. It feels so good to drive a sports car that handles like one /ubbthreads/images/graemlins/laugh.gif It handles so good now, I think all the suspension "upgrades" I've been thinking of are no longer needed...
except one... And that is to lower the car an inch or two. I hate looking at my car next to others in the parking lot. I can see I have the same ground clearance, but given how much more narrow the 'B is compared to other cars; the 'B looks like it has a lift kit on it. /ubbthreads/images/graemlins/eek.gif
My labors over the summer are now beeing enjoyed. I think the last thing "bugging" me right now is the wiring harness under the dash. Hopefully, this weekend will cure the connection ailments under there. /ubbthreads/images/graemlins/smile.gif
