Bruce_B
While wiring up my '59 BE (And having way to much trouble with it) I decided just to zap the starter to turn the engine a little bit and spread the lube in the pistons.
So it's a high-torque starter internal-solenoid, rebuilt engine, Positive Ground. The NEG cable goes to the start/switch solenoid, the other part of the solenoid gets connected to the starter. I then put 12v NEG to the space on the starter and WHIRRR. I can hear the starter spin. The starter spins even when I'm not pulling on the STARTER Switch.
Though I needed NEG to both terminals on the starter to get it to activate. And even if it doesn't shouldn't the engine move . Seems that the flywheel is not being engaged.
Any ideas?
Any ideas?
Hi Guest!
