bighly
OK so I popped for new solinoid, relay, throttle switch and lockout switch for the BT7 sideshift. When I first adjusted the solinoid it would not go into overdrive (lever hole lined up with hole on OD). I then adjusted it just beyond the hole and it went into overdrive nicely but would not come out. I then readjusted to the halfway point and it worked great until it all warmed up. Then it would "slip out" of OD. At that time I discontinued use of OD.
Yesterday I went to readjust again and noted that the wire to the solinoid was fried open. Well I fixed the wire only to find out that the solinoid is a dead short from the wire to ground (positive/chassis/solinoid body). So I believe the solinoid is shot (new Moss part marked Lucas England).
My question is would the OD cause this? It obivously has not been rebuilt since manufacture. I have followed the various guides on adjustments for both the throttle switch and the solinoid lever.
I sure hope I don't have to pull the thing for a rebuild, but if I do what am I getting myself into? Can this be done without pulling the motor? Is there a recommended rebuilder in the SF Bay area and what kind of (ouch) cost am I in for if this is the case?
