Just installed a new HT starter. Thing wont turn over the motor. Just clicks and clicks. attached movie. Need help to know where to look.
58' TR3 pos ground
I was having an issue with my old starter spinning but not throwing the bendix out to start. With an excuse finally, I bought a HT geared starter for replacement without troubleshooting the circuit. It now appears the starter was not the issue.
May have a battery issue or could be a grounding issue. I had recently replaced the selinoid when on a drive ehen I first had the starter fail. Currently using the external selinoid.
In the morning I'll check and clean the grounds. Battery already shows 12.4 volts but will load test it also.
Where to from there? already bypassed the xelinoid with the same results, just clicks. The ground ohms out on the starter.
Frustraiting electrics on this thing.
Duke
58' TR3 pos ground
Duke
