New floorboards...
G
Could anyone tell me how difficult it is to change the floorboards on a TR6. Can it be done while the body is on the frame? If so, how does one go about painting the newly welded in floorboard between the frame and the bottom of the floor, ie, all the tight spots. I realize that if it is doable, the entire interior has got to come out. What about gas lines, etc., with all that heat? Mine have major pinhole rust that crept up on me. Even though I coated it all with epoxy paint coating, think I am willing to weld in new ones. Unless someone changes my mind....
Bill
Bill,
I will not call it impossible, but I can not envision how one would or could accomplish a proper total floorboard replacement with the body still on the frame. The open areas would be fairly easy, but there are at least 11 mounting bolts on each side that would have to be taken into consideration. I read somewhere that when these cars were built, the first 2 parts laid into the body jig were the floor boards, so they truly are the heart of the body.
Not to scare you, but you should also take a hard look at the sill mounting brackets that are welded to the floorboards. These may need to be replaced along with the floorboards.
Hi,
Don, sorry but I respectfully disagree. Floor panel replacement can be done with the body on or off the frame. In fact, many think it's best done on the frame.
I've got a similar project on the driver's side of my TR4 (brake fluid leak!) so have researched it extensively, I've seen it done on several TR2 through TR6 cars, and will be doing the job soon myself. Since the inner body of the TR6 is so similar to my earlier car, it's pretty much the same job. (IRS chassis differences are mentioned below.)
Most often the recommendation is to replace the floor panels with the body *on* the frame, and one side at a time. Many think this to be the best way to assure everything lines up properly.
Keep in mind that these cars, by modern standards, were essentially hand-built and there is often some variation in the way body parts fit together, from one car to another. I think you'll find that any replacement panels you buy need some fine-tuning to fit.
The factory used a lot of jigs to position and hold panels and components in their proper location, while building the car. Those jigs aren't available to us, so the next best thing is to use the adjacent panels as our guide.
In fact, I'm putting the finishing touches on a newly restored frame for my car now, and - as soon as suspension brakes, fuel lines, drive train, exhaust, etc. are all installed - I will move the un-repaired body off the old frame and fit it to the new *before* doing any body work. Later, when the body tub work is completed, I'll remove and disassemble it again for stripping and painting.
You do have to be cautious welding around other parts such as the frame, fuel lines, brake lines, etc. Be very careful of grinding sparks and weld spatter, too. These can damage glass and start fires.
There are various ways to contain the heat and protect those items. But, you still might end up touching up some paint. I'd suggest using MIG rather than gas welding, and go slow with small tack or stitch welds, letting it cool and coming back to in-fill a little at a time. This will help keep from damaging surrounding parts or warping the panels themselves from over-heating.
Another thing to consider is partial-panel replacement. The rear portion of my driver's side floor is fine, so I will likely only replace the forward area, creating a welded seam across the floor under the seat. The replaecement panel I bought is the full floor area, but I'll just trash the left-over portion.
A seam might be a problem for someone looking for concours-level originality, but will be pretty well hidden under the seat and can be virtually invisible with a little work.
I agree the support brackets might be a problem, too. While you are in the area, also look carefully at the B-post base (below the door latch, behind the trim panel) and the rocker panels, as these are likely problem areas if the floors are seriously rusty from general exposure (as opposed to the brake/clutch fluid leak). Rocker panel replacements are available, B-post repairs can often be done with a fabricated patch (hidden under the interior trim).
Since yours is an IRS car, floor panel replacement is a little trickier than on my solid chassis car. When some panels are removed from an IRS car, the more flexible chassis can allow the A-post (door hinge post) to droop, in particular. Extra support might be needed before cutting out the old panel. This can be as simple as a jack and some wood blocks and/or some tack-welded temporary supports.
I suggest getting hold of some of the restoration books covering your car and looking for more info. Floor panel replacement is really a pretty common repair and is often detailed in the better books. The relatively new series from Roger Williams is one I'd recommend, although I've not read the book covering the 6-cylinder cars.
Alan,
I would agree with the idea of replacing the floorboards while still on the frame except in one of the restoration articles I read, they replaced the inner and outer sill while on the frame for all the alignment reasons you mention, but removed the body in order to do the floorboards. I do not recall why, and of course, I cannot find the article now. Regardless, the body alignment would still need to be maintained and that is something I did not mention.
When replacing the sills on the '75, I set the body on an extra frame so that work could proceed on the frame and body at the same time. Having both sub-projects going on at the same time in the same place worked out very well.
Bill its a dirty job but quite doable if you have the right tools. One trick I recomend is to paint the panels before installing.The seams will be caulked and undercoated latter anyway, and if you really want can be spotted in where burned back in the welding. I also recomend NOT cutting out all of the old flooralong the sill, if possible leave 1/4 inch lip to set the new panel onto. Good luck!!
MD(mad dog)
