G
Awright, here's a problem that I am faced with and need some good sound advice. My TR6 is solid, except for the front half of both floor boards. They are pitted and thinned out to the point of having multiple large pinholes, created by stupidly leaving carpet in for six months and never bothering to dry out beneath them. I have two new Heritage floor boards and want to change out the front half of both floors. Can this be done with the car sitting on jackstands from the the frame or should it be riding on its suspension. Interestingly, when the car is on jacks, the doors stick a bit, on the ground they work fine, hence frame torque. Can this be done leaving the doors on and opened to allow access to the work area? I have seen where the A and B pillars are welded together, this ain't gonna happen. I would like to cut out one at a time, MIG in new ones and move on. There is the problem of fuel and brake lines beneath the floor to deal with as well. I realize the whole interior has got to go and lots of welding blankets used to protect the car from flash will be needed. Will I screw up the car by doing a hemisection of one floor at a time? Really need to pull the heater (if TRF ever comes up with squirrel cage fan for the rest of the new heater parts I have in stock) and would pull the dash to accomplish this. Pulling the dash would give me the opportunity to push the wiring harness up and out of the way. The resulting new floorboards would be just painted black (not worried about colour matching). Bottom line, I want to do this as painlessly as possible, not respray the car and not screw up alignment of doors, hood, etc. I would even be open to giving up many pictures of dead presidents to have this done professionally if such a service existed within a reasonable radius of south Louisiana. Comments and suggestions would be appreciated.
Oh, and from the voice of experience, never "ride'em hard and put'em up wet" like I did for a year. Just ride'em hard and DRY'EM!
Bill
Bill
