Salyers890
ok, here's my latest rant. I finished my engine swap - put the 1275 in and got everything hooked up. This engine was rebuilt some time ago, so i primed the oil pump and put a little in each cylinder, filled her up with motor oil and coolant. then i set the timing (took me a while). then poof, my back gives out. i sit on the project a few days to allow myself to heal. then today i hit it hard. after everything was double checked, i noticed a fuel leak in one of the old rubber hoses, so it was quickly replaced. now i wanted to get that sucker started.
cranked it over and vroom it started up. there was a little smoke but i figured that's from when i squirted the cylinders. Also, i was expecting a little strange smells/noises from the new rebuild.
i let the engine run and warm up by fooling with the choke, and i had to fiddle with it a little bit to keep it running. then i looked back and saw a cloud of smoke. it seemed that when i gave it some gas, or over choked it smoke poured out.
this went on for quite a while until i saw what looked like black burnt oil coming from my tailpipe.
now since i set the timing statically and 'eye-balled it' to get it running, i know the timing is at least a little bit off. the carbs need to be tuned, and i just filled them up with dashpot oil. what do you guys think is going on? if i left anything out you could use to help me diagnose the problem, let me know.
mike
mike
